Router Recommendations - Cable & ADSL & Long-Range
19 Jan 2003
Bristol, UK
I am currently installing a lot of wireless networks (domestic installs) via my business.
The majority of my customers seem to be on Telewest and I was having good results using a particualr Buffalo cable router. However, this model is no longer available. I have never really found a decent wireless ADSL router from the different brands I have tried.
I would find it most helpful if I could have some recommendations for the following products, the most important factor is reliability- both build quality wise and connection.
Wireless Cable Router
Wireless ADSL Router
I would also find it useful if you could recommend the above but with some degree of range boosting technology. I am reluctant to venture into 802.11n technology until it is properly finalised.
I do have a few customers where a standard router just isn't kicking out enough power to pick up a decent signal in the rooms the customer needs to.
Your input is much appreciated,
Chris
For an ADSL router I would recommend draytek or billion. The wireless on the billion router isn't as good as the draytek but otherwise they are both excellent adls modem/routers.
i'm not too sure if this brand is available in UK..
there's a Buffalo High Power wireless router which is quite popular....
I use the buffallo WHR-HP-G54 and has been flawless for me. We'll apart from when a storm blew it but it was replaced under warranty :D . Still available to buy from a broadband online store ;).
So this is available in the UK!!
the range for this High Power is better than its High Speed model..
highly recommended...
I have been looking up networking over power cables.
If the two pc's are on different mains rings will it still work?
