I'm doing my CCNA course at the moment, and have come onto something that has not been explained compleatly so i am hoping i could find out here.
Basicaly, the course talks about using a serial cable connection to connect a router to a WAN, or between back-to-back between routers in a lab environment. It talks about that when using a serial connection such as this that a device on one side is DTE (a router in this case), and on the other side of the WAN is a DCE which does the signal clocking and such (and in a lab environment will be the job of one of the two routers).
Now my question is this, why does connecting these type of routers require such an interface/cables? why is it not simply possible to connect to the WAN via a fibre optic interface (which i assume is what big companies and such use to provide their internet access). Also, what is the point of such a variabl clock rate system? can it not be simplified like ethernet? why does one device have to generate a clocking signal? The course im on says that on an ethernet connection, the devices use the signal of the transmited data itself as timing.
Finaly i have one last question for now. Currently my course says that cisco routers connect their rj45 console port to a serial port on the PC, now since most modern PCs lack a serial port can i expect cisco to create devices that connect to the console port using USB or an ethernet port? (For all i know cisco already do this, but since this is a CCNA it deals with some old equipment, and so the brand new cisco gear that may have given up on using serial for console connections wouldn't be in my course).
You can get serial port switchers though they just allow you to select which device you want to talk to.
