Hi
Wasn't sure on best place for this but it is prob more DIY.
This is a small room on ground floor under my stairs. The house has virgin media ports and network ports in lounge/kitchen/4 bedrooms, they all come to this room where they meet the virgin connection from outside. It also has the BT box but that won't be used.
It is currently a mess as we have just moved in and i just wanted to get internet and my PC working.
I want to mount everything on the wall for easy access and free up the floor space and also sort all the cabling so it is nice and neat and easy to do what ever i need to do if i change anything.
Should i attach some kind of wooden board to the wall and mount everything to that or just go straight on to the wall (plaster board) with everything?
I'm thinking it might be easier to mount everything on a 'tray' that i then attach to the wall.
Anyone got a room like this can show me what you have done?
There will be a lot more wiring as i will set up a small PC in there and also connect up all the other rooms with a switch going in somewhere.
Thanks,
Thanks,
