Router with dsl modem?
5 Nov 2005
Im currently using the BT voyager 105 usb modem that I got from bt when I ordered broadband but now I have upgraded to max adsl and need to get a router with built in dsl modem to get full speeds. I have been looking at the bt voyager 240 but this has been showing 1-3 days for a long time so does this mean I will recieve it in 1-3 days or that overclockers will get it in stock in 1-3 days?
also, there is the Netgear DG834 router with adsl modem would this be better or is there another you would recommend?
thanks for any help
Bobmunkhouse said:
I had the option of a wireless one but it only had one ethernet port which I dont want. Im on BT option 3?
I thought they were only doing instant regrades on the 'option 4' package :/ . Hey ho. I took out the regrade to 'option 4' & had the oppurtunity of the V2500 for free, I am sorry you seem to have missed out :(
So spend a tenner on a switch and use that to give more ethernet ports. Only having 1 ethernet port doesn't mean you can only run 1 PC from it.
the reason you get the 2500v on option4 is because you also get btbroadband voice and you need a voip capable router. if you were to choose option 3 or option 4 without the free broadband voice, then you get the 2091.
