Routers with BT Voyager help
14 Jan 2006
Hello,
I'll try and explain this as best I can and hopefully someone can offer the advice I'm looking for! :)
Basically I have been asked by a family member to look at their internet connection, and on reaching their house I noticed they are using an old BT Voyager 210 USB router, meaning they have to click connect on their computer every time they want to use their internet.
This seems a bit outdated to me and as well as this they want to have wireless internet enabled, something this old USB router doesn't offer.
If I was to suggest to them to get say a Belkin ADSL router, would this work fine with the BT Voyager connection they are paying for? As in, would BT be able to offer the correct connection details for using a non-standard router.
Hopefully I've explained that well enough for someone to work out what I'm asking!
Thanks
From the sounds of things it sounds like they're on a very old BT package? Maybe they should upgrade to one of BT's newer ones? Then that way they'll get a free Home Hub 3.
But yes, as long as you have the BT details and set it up on the ADSL router it will work fine.
Yeah they're on an old package. They live in the middle of nowhere so it's the best they can get. I just needed confirmation that I'd still be able to use a newer router on the connection they have :)
Contact BT, say your getting problems with the BT Voyager & you should get offered a free upgrade.
Worked for me when my sister had problems with same kit.
Should do. I did it with a Tiscali connection a few years back when they was also using USB modems. Swapped it with a Belkin to fill the house with wireless.
