Hi, I'm hoping someone who is familiar with network routing can help me.
I'm specifically trying to connect 2 routers in different locations of my house and the clients on each router seeing each other's devices.
I've drawn the following diagram to help.
Problem 1: Devices connected to the Linksys router cannot see devices connected to the ADSL Modem router. However if I connect with my wireless laptop than I can see devices on both routers. It is as if with a wireless connection both routers are bridged together, but not if hard wired into the RJ45 ports.
Problem 2: My PC will only connect to the Linksys router if I add a 2nd homeplug to the router. I want to get rid of the 2nd homeplug on the Linksys because it doesn't make sense to me that 1 router needs 2 homeplugs.
I've setup a DMZ on the ADSL Router to connect the 2 routers but I think this is not the best way to connect the 2 routers. I want all my devices to see each other as 1 seamless network. ADSL router is connected to the WAN port of the Linksys WRT54GL.
I think I need to configure a static route but not sure in my assumption, or how to do it.
Here is my current routing table on the Linksys router (which has a tomato derivative firmware which is very similar to dd-wrt).
Some more settings:
Update: I want the Linksys Router to be master of the LAN, and the ADSL Modem Router to accept and share the internet and act as an access point including wireless. The ADSL Modem Router is a Technicolor TG 582n router from TescoBB.
Some more settings:
