I've got an issue with my route (Cisco 837) and getting at the external ips from inside the nat.
I've got a block of 5 usable public ips, and ports from these are natted to various internal ips in the 192.168.0.0/24 network. I have dns names set up which map to those external ips, so I can access the servers from the internet. However, if I'm inside the private network, I can't connect to the public ip and port. I can access it on the relavent private ip, but the public ip doesn't route there for some reason.
For example, if I forward port 80 on public ip 88.96.111.10 to 192.168.0.4 port 80, then I can't connect to 88.96.111.10 port 80 from inside the private network.
I'm guessing it's a nat issue, as I can use ipv6, which isn't natted, to access the servers. But then there isn't the concept of a "public" and "private" ip for that. Anyone know what I can do to enable this?
