I have a Juniper SSG 140 which has our ethernet internet circuit on the untrust interface and our local network on the trust interface
I need to add an adsl connection to another interface which I have done and created a new zone for that, call it 'ADSL' for arguments sake
With the ethernet circuit when I first set it up I had to manually set the default route
When the ADSL comes online and it dials the PPP it automatically adds a default route into the routing table, because it is a connected route it takes precedence over my static route for the ethernet circuit which cause us a few problems
Is there anyway I can stop it from putting this route in? If not then if I change the preference of the static route I created to 0 will that resolve the issue?
Thanks
Thanks
