Deleted member 329
Deleted member 329
hello!
ok well i have a problem.. as some of you may know i reciently got my hands on a rover 214i, it needed some work which has now been done.. but i have a slight problem which needs looking at and i am at a loss.
it had work done to the engine which involved disconnecting the battery. and now the immobiliser wont go off. anoying thing is that i dont have the code that comes with the car! and i cant find a garage that can recode it or what ever needs done to get it working again.
does anyone have any solutions?!
thanks!!!
thanks!!!
