Rover 400 Cam Belts
1 May 2003
I have just had my Rover 420SLi R Plate serviced, and the machanic has asked me the last time the Cam Belt was changed. I told him that I would ask my m8 who I bought the car from, but he doesn't know.
Does anyone know roughly how long these belts are supposed to last (in miles). I cannot be sure when if it has been changed at all. the car has done 61k miles :confused:
TIA :)
Service interval is 6 years or 60,000 miles, which is probably why the mechanic asked.
Ok, thanks for that. The mechanic quoted me a price around the £200 mark for the cam belt plus fitting.
Is that a good price or the average going rate, or a rip off :confused:
I paid £415 for the following:
- Cambelt
- Cambelt tensioner
- Water Pump
- Rear Cambelt
- Intake O2 sensor
Since the water pump cost £80, the sensor was £30 and the rear belt was £25, all things you wont have to change the price I had to pay was £280 but that still includes the labour charge for doing those extra jobs which probably took about an hour longer. So had I just had a normal engine with no extra bits I would be looking at around £230 for a timing belt swap so your price looks ok to me.
