F355 said:Anyone know any good metro forums?
My neighbours car won't start. It has fuel getting to it but just turns over, trying to start but failing.
After owning a mini you should know all of the tricks! Is it getting a spark?burns said:The guys on retro rides could probably help, there's a few on there who have/have had metros.
You checked for a spark against the block when you turn it over? Don't some coils run on less than 12v? eg those with ballast resistors. Not sure if the metro would.
Do you get any dash lights at all when sticking the ign on? Do the dash lights dim when you turn the key over? If so, points to a dodgy batteryci_newman said:What he saidDo you get any dash lights at all when sticking the ign on? Do the dash lights dim when you turn the key over? If so, points to a dodgy battery
