- 25 Apr 2011
- Crawley/Gatwick
Morning
Looking to replace wifi antennas on the motherboard
From what I gather DBI is the range or the capability of the antenna to broadcast signal
I recon around 8+dbi should be good to go for a home use
2.4+5ghz dual band
Am I looking for anything else?
I mean length is important, can sized is better than usb sized.
Not looking to get anything wired, just screw at the back and forget about it
Any help appreciated
2.4+5ghz dual band
