Referring to this link
http://forums.overclockers.co.uk/showthread.php?t=17664680
Kindly look at this link below (i know it is oracle) , you can see the Oracle server has got another name which is RADUIS client as well
http://www.stanford.edu/dept/itss/docs/oracle/10g/network.101/b10772/asoradus.htm
Figure 5-1
1- Does the similar concept apply to VPN and RADUIS and SecureID (Token) ?(i.e. VPN is Raduis client )
2- In the diagram below :
http://www.auckland.ac.nz/security/images/2FAReportv1.pdf
Which one is RADUIS server and Which one is RSA ACE/Server ? My guess is the middle is RADUIS server,,,,Am I right ?.
3- if I have got cisco RADUIS server , do I need to use RSA ACE/Server as well , because RADUIS does support two-way factors Authentication
Figure 5-1
https://www.gotomypc.com/help/using_gotomypc_features/rsa_securid_integration.htmhttps://www.gotomypc.com/help/using_gotomypc_features/rsa_securid_integration.htmRADIUS is a two-factor authentication method based on something you know
