RSV6-2 Wireless X360 Gamepad Fix
8 Dec 2005
Edit PCKellerJoysticks.ini to include the below:
[Joystick0]
ProductName=XBox Controller HID Minidriver, XID
VendorID=1118
ProductID=0673
UseXInput=True
This is for Vista 32 + SP1 your VID\PID values may vary depending on your OS. The parts in bold were changed.
You should now find ingame you get the button names appear just the same as the 360 version and you get an extra menu in the controller options section.
This fix is especially for all you fellow HDTV PC gamers:cool:
Excellent thanks.
Just tried it with Vista x64 and it works great. Lets you now turn on the 360 controller in the options screen. Its the same controls using the controller as the 360 version.
I find it much easier to play with the controller then keyboard n mouse.
Ill start from the begining again now.
Cheers again :)
Awesome, cheers !
Looks like its something Ubi could easily patch to fix too, so i hope they take note :).
