I recently upgraded my own rig and my Dad now has my old Sapphire RX 6800 XT Nitro that I had from new, a big upgrade from his aging 980 Ti. Wanting to show him what the GPU can do I fired up some games and benchmarks, all good other than some coil whine from his PSU.
That was until I tried to show him some RT effects. With RT on, the Witcher 3 will crash within a few seconds of loading a save, RT off no problem. Cyberpunk will crash about 50% of the time during the benchmark with RT on. Wanting to try something that wasn't the Red engine, I downloaded the UE based Bright Memory benchmark. Again it would crash about 50% of the time.
When I say crash, in all instances it is a soft crash, never a hard crash, the game will crash and trigger the AMD issue detector driver timeout error, along with the engines own crash error. Thinking it may be PSU related I tried OCCT power test with GPU set to +15% and no problem. Any game or benchmark without RT even with the GPU pulling 330W is also fine, again apart from the coil whine.
I used the Bright Memory benchmark to play around with some settings. I found that putting the GPU power tuning settings to Quiet mode (270W TBP), it could loop the benchmark for 30 mins without crashing, conversely putting it up to 15% power increase it would crash 100% of the time. It still crashes in Witcher 3 with RT all the time, but that change in Bright Memory to me was enough to be 99.9% sure it was his 13 year old HX1050, especially as it was whining under load. I assumed the GPU was becoming unstable when trying to run the more intensive RT calculations.
I fit a NZXT C850 (the newer ATX 3.1 version) and although it's "only" 850W with it being designed for the power spikes of modern hardware, it should still be plenty. Cue my frustration when it doesn't fix the issue!!
Things I've tried:
Update BIOS, DDU, latest and 2 previous driver versions, uninstall or stop non-critical background software, including anything which could be polling hardware. Turn Re-sizable bar off, set graphics driver settings to default, try memory sticks individually, run the RAM at less than half its rated speed. Probably more!
I've never had anything stump me quite like this and I'm running out of ideas. I was so sure the PSU was the culprit. His specs for completeness:
Ryzen 3800X under Freezer II Pro 360
Crosshair VI Hero (BIOS 8801)
2x 16GB Corsair 3600 CL18
Was a Corsair HX1050 PSU, now a NZXT C850 (ATX 3.1)
Win 11 Pro
Any ideas at all at this point, if I haven't already tried them I'm up for giving it a go.
TL;DR: Ray Tracing causes crashes, worse with higher power use but it's not the PSU.
Things I've tried:
Win 11 Pro
