RT-N53 wireless issue
21 Oct 2002
UK
Hi all,
I have the above router and the wireless keeps dropping. I don't know what to do to fix it. I currently have my PC wired to the router so it's fine but my phone and my iPad connect but can't get any internet.
I usually have my PC connected wirelessly and when it works it's perfect. However when the wireless drops I turn off the router, wait 5 mins and turn it on again. I get a wireless signal but it's limited (not sure what that means?) and I can't access the internet or get access to the router. occasional restarts, leaving it off etc and the wireless will work again, maybe for a few hours, maybe for a few days but the issue will happen again.
I am currently on the latest firmware (I briefly tried tomato on it but had similar issues). I only use 2.4ghz connection if that makes any difference. Where my PC is usually located this gives a better signal than the 5ghz.
It's only the wireless that I have an issue with as it works fine with a wired connection. Does any one have any advice?
