RT7 Light Slipstream File too large
29 Dec 2007
Hereford
Slipsteamed Win7\Sp1 using RT7 light beta. The resulting file is too large to fit on a VDV, (8.16 Gbt.) It wont even fit on a dual layer DVD. Is this right?
something has gone terribly wrong. :p
i've never used it myself but i can't see the ISO being any larger than the official SP1 ISOs. 3.2GB or so for x64, 2.5GB for x86
If its like mine it will be trying to fit the files from the original dvd onto the disc as well, just delete them and use the modified ones.
