Rtrim... ish
18 Oct 2002
hi guys,
i've got some data i want to apply an rtrim to, but it doesn't necessarily have spaces at the end of the field. example:
Code:
Celebrations                                   [D]
How can i remove all the annoying spaces and keep the "[D]", or whatever it is, at the end?
B@
You can use a regex to replace multiple spaces with one, here's a C# example:
Code:
string test = "Celebrations                                   [D]";
test = Regex.Replace(test, @"\s+", " ");
If you're using SQL Server and C# then you can write an assembly that calls the C# regex functions, deploy it to the SQL Server and then expose it via a SQL scalar-valued function.
So if you have SSMS installed you want to be looking at the Datbase\Programmability\Functions and Datbase\Programmability\Assemblies folders.
[EDIT]Just found what we use:
Code:
    [Microsoft.SqlServer.Server.SqlFunction]
    public static bool IsRegexMatch(string Input,string Pattern)
        // Put your code here
        Regex reg = new Regex(Pattern);
        return reg.IsMatch(Input);
So we have a C# assembly with that function in, we published the assembly to a SQL Server database and then created a SQL function that basically points to that assembly function.
You might want to put some error checking in there as it will throw an exception if you give it a NULL string :o
[EDIT2]Just realised that just checks for a match but doesn't actually do a replacement. I'm sure you get the idea that you could use Spunkeys code in one of these functions and then call that :p
probably not the best solution, but the following should work:
PHP:
declare @myval nvarchar(100)
set @myval = 'Celebrations                                       [D]'
select replace(replace(replace(replace(replace(@myval,'     ',' '), '    ', ' '), '   ',' '),'  ',' '), '  ',' ')
Tried with various lengths of spacing, and it seems to work.
that would replace all spaces wouldn't it?
B@
Sure, I'm guessing that's not what you want then? How common are the last few characters? You may want to write a stored procedure that removes the last 3 chars, then trims and replaces the last 3 chars.
PHP:
this works perfectly, thanks very much!!
B@
