I've just installed a ASUS RTX 2060 Dual EVO OC 12GB and according to the specs my clocks should be:
Boost Clock: 1680 MHz
ASUS OC: 1710 MHz
I'm using Asus GPU Tweak iii for monitoring and fan control purposes and it's reporting my in game clock @ 1950 MHz. Temperatures are low 60's - I only was in game less than 5 minutes so temps will rise. Should I be worried.
I'm paranoid because my previous GTX 1060 overvolted and overclocked itself by a huge margin after updating drivers. It was too late before I realized, but the damage was done. I was using default settings but Afterburner was running during the update which may have messed up the update.
ASUS OC: 1710 MHz
