Hi, new to this forum so please be kind.
After having my last build for over 5 years, earlier this year amid lockdown I treated myself to a new pc, the old one was rock solid and never let me down it was just showing it’s age it terms of GPU performance and I had pushed the CPU as far as I was willing with OC. So it meant a whole new rig, so I could pop in a shiny new GPU.
Happy with being able to run most of my games maxed out but I have started to have random crashes in a few games.
New build general specs are
MSI MPG X570 GamingProCarbWiFi (it was all that I could find in stock)
R5 3600 Stock
32GB Ram
RTX 2060 Super 8GB
1TB Intel 660P M.2 as OS drive
4TB BarraCuda HDD for steam library
I even sprung for a new copy of windows as I am still using my old computer.
So software wise
Windows 10 build 19041.450
Direct X 12
GeForce driver 425.06
It can be fine for hours and then one of two messages pops up I click ok and I am booted out to my desktop. I can then reload the game and it be fine again for a while then it all hapens again the timing seems random.
DirectX function “GetDeviceRemovedReason” failed with DXGI_ERROR_DEVICE_RESET (“The device failed due to badly formed command”). GPU: Nvidia Geforce RTX 2060 Super”, Driver 45206
Or
DirectX Function “GetDeviceRemovedReason” ” failed with DXGI_ERROR_DEVICE_REMOVED (“The video card has been physically removed from the system or a driver crash or upgrade has occurred.”) GPU: Nvidia Geforce RTX 2060 Super”, Driver 45206. This error is usually caused by the driver crashing: try installing the latest drivers. Also make sure you have a supported graphics card with at least 512MB
Now I am guessing this is a driver issue as I am not removing my GPU mid game, I have tried to update GPU driver but I am running the latest and I have also tried to roll back the driver via device manager but the option is unavailable. So I am turning to you lovely people for any help or suggestions.
Thanks for reading.
R5 3600 Stock
32GB Ram
RTX 2060 Super 8GB
So software wise
Direct X 12
Or
Thanks for reading.
