Hi all,
Following system:
i5-4690k (stock), MSI Gaming 3 Z97, 16gb DDR3, Zalman ZM500HP 500w psu, MSI RTX 2070 Gaming 8gb, Oculus Rift, SSD and Seagate drive.
After some time with the rtx 2070 I’m getting some mega artifacting both in VR and on a standard monitor in the only games I play ACC and ProjectCars2.
I’ve played with underclock of gpu in afterburner and no change, even with a voltage boost to 100%. Likewise I’ve run the cpu at oc’d to 4.6ghz but still getting the issue, assume as it’s gpu related.
I’m stuck where to go next. I was about to upgrade cpu, mobo and ram to a 9900k, z390 board and ram, but now I’m also thinking I need a new psu and also rma my gpu!
is there anything that could be causing the artifacting other than vram issues on the card? Ie do I need to give it more grunt from a better psu?
I think a new psu would be needed anyhow for the big jump to 9900k as the zm500 is now ancient and probably dying.
If anyone can help shed some light please do!
thanks
A77D
Following system:
thanks
A77D
