RTX 2080 in 2025??
15 Oct 2007
Bedfordshire, UK.
So my brother's GPU (1070) is acting up so needs a new GPU. Budget is tight (approx £150) so will need to be a 2nd card. Does the 2080 cards still cut it at 1080p gaming in 2025?. He's currently on a kick playing Hell Divers 2 and Ark Raiders.
Or is there something better to look at in this 2nd price range??
Yeah looking at prices, there doesn't seem to be much difference between a 20 series and a 30 series cards.....odd.
Is there a large performance difference between say a 2080 or a 3070?
There's a pretty healthy jump:
The AMD 6800 should also be considered if one can be found for a similar price, about on par performance wise but you get more VRAM with the 6800.
Might be helpful to gauge how they stack up, and versus newer cards.
If the budget wasn't so strict, then I'd suggest an Intel Arc B580 would likely be a good shout
What is the driver support like for the Intel cards now a days?. I remember it being an issue in the past
I'll have a look at these. I was a bit concerned about the older RTX cards only having like 8GB but I guess for 1080p gaming that's still ok?
As long as he's happy turning settings down here and there I can't see it being a huge problem, but it does depend on the games.
Personally, if a 6800 and 3070 were the same price I'd feel more comfortable getting the 6800. AMD has less driver overhead too, so if he's on an older CPU it might be an added benefit and eke more performance out.
Either way, he'll enjoy a big upgrade over what he currently has, so I'd not get too caught up.
Regarding Intel, their drivers have come a long way, just make sure whatever PC he has supports REBAR as performance can be very iffy without it.
He has a Ryzen 5 3600, so pretty old now.
Interesting point on the driver over head, never thought of that. Do AMD cards still use more power and run hotter than Nvidia cards?
What on earth is REBAR??, I'm completely out the loop
There's not much between the 3070 and 6800, at 1080p around a 10w difference on average:
ReBAR = ReSizeable Bar, it basically allows the CPU to better make use of your graphics cards memory. On some GPU's it doesn't make much of a difference, but with Intel it can be pretty huge.
If he's on a 3600 he should have Rebar support, it might require him to update his motherboard BIOS, you'd need to check on the specific motherboard he has.
