So I'm having an issue, my new RTX 2080 super FTW3 based arrived and I had a play overclocj3d my memory to 1200 fully stable no artifacting nothing smooth as silk. I have then turned my new CPU got it stable at 5ghz and decided to have another play on my gpu and now when I set my gpu memory to anything 1000 offset and above I get artifacts and the system hangs and restarts.
I set it to 900 offset and it seems ok but I'm confused not just by the fact my OC has dropped but by the fact my system hangs restarts. I've also had the same issue with EVGA OC scanner whereby I click scan and my system just restarts.
I'm ali having some strange system behaviour like overly long windows loading time on restart but it fast from clean boot.
Could my psu be the culprit it's a very old and heavily used 1000w evga g2
