I found a non LHR RTX 3060 for £399.95 on Overclockers, I wanted to check that it is LHR as it does not say LHR in title however, the price is over £100 cheaper than other RTX 3060 cards.
All 3060s are LHR that's why it's not advertised as such as there was never a non LHR version, it's the same with 3070ti / 3080ti.I found a non LHR RTX 3060 for £399.95 on Overclockers, I wanted to check that it is LHR as it does not say LHR in title however, the price is over £100 cheaper than other RTX 3060 cards.
https://www.overclockers.co.uk/zota...ddr6-pci-express-graphics-card-gx-12f-zt.html I think it is LHRIt should specify somewhere, but most (if not all) recently manufactured cards will be LHR, especially on OC. If it's from the pre-order stock listed today (Inno3D cards), then it is LHR. If you send the link in this thread, should be able to check. Either way, that's a great price, though I believe the Ti models are currently on for £430 which is definetely worth it imo. LHR or not doesn't make a difference for gaming, only for crypto mining anyway.
From what I can tell, I imagine this is an LHR. The 3060 & 3060Ti launched with it's own version of LHR, so this is unlikely to be LHR. OCUK are generally pretty against crypto mining GPU so I find it very unlikely they would sell non-LHR, especially as those are very hard to acquire, and generally aren't manufactured anymore.
If your not a lowlife miner then you have nothing to worry about
What happened to your 6800XT? Sold it or have I got you confused with someone else?
If I may - what is LHR?
