RTX 3070TI
12 May 2016
Hi all, brought a 3070ti to replace my 2080super, but the monitor says no display every things plugged in even hdmi will not work put the 2080 back in and every thing is fine any thoughts or do you think the card is damaged any help would be appreciated
Regards mark:)
Some people have required an upgraded display cable from card to monitor to get a signal
If you haven't tried already - stick the 2080 back in, run DDU to remove all drivers, remove 2080, install 3070TI, install latest drivers.
eta - re-read - sorry Sunday :-) if you are getting the screen reporting no input then drivers are not likely to be the problem. Re-seat, 2 distinct power cables from the PSU to power it and different cable are all the right ideas.
HTH
Update your motherboard bios with the 2080 in and then try the card again. Also if you are using a riser to the gpu then that could be the issue too and you need to set the pcie slot to gen 3 pcie not 4.
Regards mark:)
Tried a display port cable rather than hdmi?
