RTX 3080 Gigabyte Vision OC Flat 8 pin to 8 Pin PCiE
10 Oct 2021
West Yorkshire
Hi all, Trying to find a cable that’s converted from Flat 8 pin to a 8 Pin PCIE found one on MODDIY however not sure if I trust them. Found someone with a pinout of them online however someone said the OC edition has different pin out not sure how true that is. I have no clue on how to make my own cables so purchasing one would be better. Just don’t want to buy the one from MODDIY and it’s got a wrong pinout
I ended up making my own for my 3070 Vision OC after getting caught out by these connectors. What you could do is order a couple of the MODDIY ones and check and double check the pinouts with the Gigabyte adaptors. If they are different just swap the pins over so that they are correct.
