- 11 Mar 2013
I can't find any SFX PSU's that are palatium rated higher then 750w? Would a 3080 Ti be ok on my Corsair SF750?
I’m running a 3080 on a SF750.I can't find any SFX PSU's that are palatium rated higher then 750w? Would a 3080 Ti be ok on my Corsair SF750?
Yes it will be fine, im running a 3090 and a 12700k overclocked on a SF750 and it handles it like nothing. These psu's can handle quite abit without any issue.I can't find any SFX PSU's that are palatium rated higher then 750w? Would a 3080 Ti be ok on my Corsair SF750?
It really is, i can't remember who did a test but it went all the way upto 850w without any issues, just works and the fan (although abit noisy) keeps it all in check.Nice. The SF750 is a small beast of a psu.
Tomshardware. It's in their testing section in the review.It really is, i can't remember who did a test but it went all the way upto 850w without any issues, just works and the fan (although abit noisy) keeps it all in check.
Ah yeah! I think maybe optimum tech or Gamers nexus on youtube did a video on it as well. I remember watching it before making my purchase.Tomshardware. It's in their testing section in the review.
I really want to but judging by how much power these new gpu's are going to need, it's hard to stay in a small box for the foreseeable future especially if the cards get any thicker than 3 slots though i'm usually watercooling anyway.I got mine on special for £100. Bargain. Been meaning to go ITX for ages. Will stick to ITX for the future too.
3090 might work on an SF 750 with its capacity of 850 watts but I wouldn't want to run that for a long time in an ITX build.I read somewhere that said the SF750 would only be good with a 3080 and any higher not be good? I did think it is a palatium PSU so it should run a 3090 at least without issue.
Got mine for the same price.I got mine on special for £100. Bargain. Been meaning to go ITX for ages. Will stick to ITX for the future too.
No personal experience of these high end GPUs, but I came in here to say that my worry wouldn't be the normal load but rather is be worried about the spikes.I had to upgrade my old SFX 650W to the Silverstone SX1000.
The transient power spikes was causing the odd random restarts whilst gaming, and I already undervolted my 3080 FE.
