3090FE stock out the box see it peak around 1995 Mhz then drop to around 1965 Mhz as it warms up. Temp wise it tops out around 68 degrees or so with fan profile at 43% so very quiet FE cooler.
Day to day, I have it at 2100 Mhz and +800Mhz on memory profile with a slight undervolt using the voltage curve. Temp wise is the same as above amusingly as its set to use less voltage then at stock. Card can peek at 2205 Mhz and I have a saved at 2175 Mhz but see no difference really between 2100mhz and 2175mhz.
Will hold this in everything bar Cyberpunk 2077 with RT on and benchmarks. This is partly as with CP2077 RT / benchmarks, game will smash into the 400w power limit. So there using a undervolt / overclock works best I find.
Normal of all of Ampere, 15mhz increments that is. Though some other people seem to mention in between numbers but not seen that on Ampere GPUs I have used and never seen in between steps. Can select in between steps in likes of MSI AB voltage curve, but it rounds up or down in my experience.
Could you show us your curve please? (that sounds so weird out of context)
