RTX 3090 Eagle water block
25 Sep 2012
Hello and Merry Christmas to all. I have an RTX 3090 eagle non OC version which i want to water cool.
I see an alpha cool esiblock can be bought for the OC version will this block fit my none OC version ?
Thanks in advance
Pulled this from another site ;
Which implies they are not listed as compatible because they weren't released at the time, but will be added to the list.
OC variants are generally the better binned chips put on the same card as the standard models.
I dont believe Gigabyte would release a seperate design pcb for just a small overclock, it wouldn't make financial sense.
Thanks for reply that clears things up. the power connector cables i would need to buy separate as the power inputs are on a block separate from the pcb ?
