RTX 3090 Watercool conversion
29 Sep 2008
Glasgow
Im looking at converting my RTX3090 Suprim to WaterCooling. Does any company do these conversions for you? As I paid over 2k for the card I don’t want to take the chance at trying it myself as I ended up frying a new GTX260 back in the day (I cried)
It's easy enough to do as long as you take your time and follow the instructions to the letter. No different than changing a cpu cooler really. Just make sure you get the correct block for your card and things should be fine. I can highly recommend Bykski blocks, high quality, good looking blocks for a decent price. Mine had to come from Aliexpress in China but only took 9 days and was much cheaper than a block from the likes of EKWB.
