- 22 Dec 2018
I’m thinking of upgrading my current RTX2080 gpu to either the RTX 4070/4080 gpu when they’re released. Currently I have an Asus Z370-G motherboard with 9900k cpu, 64Gb of Corsair vengeance ram (3,200MHZ overclocked to 3,600), an EVGA RTX2080xc and EVGA 750w psu. I know the PSU is probably the most likely first thing that needs upgrading. But what about the CPU? I’m sure a better one would benefit. But this is where recommendations are needed. I guess I’d aim for similar but newer versions of current set up, like the same level of product range for motherboard and if not one of the top end CPU’s best of the average type. But is it also wise to go for DDR5 ram? I also have lost a little faith in Asus boards found their bios updates caused problems so thinking of maybe EVGA or Gigabyte. The main reason I want to upgrade is I now have a 4k tv and can only get fairly decent frame rates if I turn most settings down. And for me, that seems like getting a really expensive tv or camera and smearing it with Vaseline. Ppl say MSAA isn’t too important, but I’ve found a lot of games, look better in 14400p on max settings than 4k with settings like MSAA turned down. Even GTA V I can only get fairly decent image quality and fps at something like 1600p. It’d be brilliant if I could just swap the rtx2080 for the rtx4080 and I’m sure I’d get improvements, but probably a melted CPU and processor. But that said, I’ve always thought it’s best to try and get the best chipset for latest gen of CPU, and try to aim for too range of second best CPU, but was fairly lucky that I was able to upgrade easily from a 9600k to a 9900k cpu and that made small differences. If realistically I’m better of just starting again, then just say. But if there’s ways I can do this in stages, any advice is highly appreciated
