- 2 Jun 2014
Hello, I already have the above components (I am building a new 4k gaming PC).
I need some advice on the rest of the build, I need hardware capable of strong gaming and streaming e.g. 32/48 or 64gb of RAM and a case big enough to fit the 5080.
Air cooling is a must, I don’t trust liquid cooled because of the leak and damage risk.
I am also looking for the best 27 inch monitor to match. I know 27 inches is small for 4k but I am shortsighted or perhaps you could convince me otherwise.
Ideally I don’t want this build to go higher than £2750 although there’s some flexibility if it’s a key component.
Thank you.
Thank you.
