. I think they would have created a new 20 series demo area for it, not left in the Maxwell 970/080 demo areaWas that 1080 Ti (no RT) vs 2080 Ti (RT on) giving same FPS do you reckon?I'm not sure any of the available demos support RTX features (yet), managed to get the UE4 infiltrator demo running but my 2080ti showed literally no fps difference from my 1080ti and with no options screen there wanst even any way to tell what res it was running in.
Right now, it seems RTX still isn't a thing.
There is a kitguru review which filmed the SW demo using a 4k camera with some fancy software to measure fps. This was done for 1080/ 1080ti/2080/ 2080 ti. Rtx cards were well on top of pascal but there was not much difference between 2080 and 2080 ti both around 40- 60 fps
The point is how many rays per pixel will be done.
The Star Wars demo was 200 rays per pixel at 1920x1080 24fps so 10 gigarays give or take (RTX2080Ti performance). According to Nvidia's CEO own words.
However how many will find acceptable this refresh rate or resolution? So less rays means less RT quality but higher FPS, and this is were it goes.
Well, the rasterization doesn't have to be done at 1080p, it can be done at 4K so that really isn't an argument.
And you certainly don;t need to get 200 rays per pixel to get great result, even 2 rays per pixel tends to give much better results than the hacks form screen space reflection and Global illumination hacks.
