RTX FE Custom Top Plates
2 Jun 2013
Glasgow
Hi,
Was just wondering if anyone knew any good websites for getting a custom acrylic top plate that I can put on my 3070ti Founders Edition.
Its just so I can try and match the white theme of my PC a bit more.
Cheers
Take it apart and spray it white job done:D
Would be the best idea but don't want to invalidate a warranty for a GPU that was hard enough to get lol.
seconded otherwise buy a piece of acrylic, cut to the shape of a top plate. Replace
Don't trust myself to make it look "clean" so that's why I was hoping there was places you could order one from. Maybe I will just need to give it a shot..
Isn't the backplate made of metal and used to help dissipate heat? my 3080 backplate gets so hot you can't touch it. Replacing it with acrylic will not work as well and may cause temps to rise.
