Hi there,
I've got myself into a bit of a pickle. I'm rebuilding a PC that I previously had a custom loop in. The RTX MSI 3080 SUPRIM X had a waterblock that is now removed.
I have the backplate and heatsink that came stock, but I'm missing all screws and the silver bracket shown below:
I believe the four screws in the bracket are: M2x7.9mm 7mm Spring OD.
The backplate should be: M2x8mm.
Any ideas what that bracket is called / where to find a replacement? I do have a dead GTX 1050 ti... Thinking i can scavenger the bracket/screws off it...
