RTX2060 w/ Freesync
2 Jun 2013
Glasgow
Hi,
Having countless issues with my new 5700XT and don't have the patience anymore to wait for a stable 100% driver from AMD. I dont want to get the 5700 as it has the same issues and the RX590 might be too big a drop for him.
I was looking at the RTX2060 but he already has this freesync monitor:
Samsung LC24RG50FQUXEN.
If he buys the 2060 can this monitor work with freesync? He will be playing at 144hz.
Cheers
There's no guarantee that it would work unless it's on nvidias list of certified Gsync compatible monitors, that's not to say it won't work, my monitor isn't on the list either and works perfectly.
To get the option to enable Gsync you need to be running Windows 10 and have the Gpu connected to the monitor with a display port cable.
