My last thread, i was asking advice on what graphics card to get, deciding whether to get a RTX1070 and didn't want to spend anything more than that as i was originally looking at RTX2060 pricing. Anyway, as the title of the thread suggests, i ended up getting the urge to really go for it (No, i really couldn't push myself to a 2080ti, so i ended up with a 2080) Queue the hate for not getting an AMD
Just wanted a bit of input on what targets i should be able to achieve with overclocking my card. Currently have it running at 2100Mhz Core and 7800Mhz Memory.
At load i have 65-67c which is at around 40% fan speed. That is after 30 minutes of benchmarking.
Should i be aiming a little higher or is that around right for a 2080?
Thanks!
Thanks!
would have been cool at 2.2ghz+ but i'm not complaining at the time 2 cards over 2.1ghz were stupidly quick, my issue was power draw so i opted for a 2080ti instead and its the first card i havent had to overclock, my frame rates at 1440p are insane everything maxed out in my collection
