Hello
TLDR - RTX 2080 ti fails when trying to draw more than 320w (approx)
Help needed from a long time lurker. Any input would be greatly appreciated. I'll give as much detail as I can. In work currently and I stopped messing around at 2:00am "last night" so my replies will be slow and from memory.
Specs -
i9 9900ks @ 5ghz (stable)
Gigabyte Auros Master Z390 MB
Gigabyte RTX 2080 TI gaming oc (with WB) - (Stable @ stock)
32gb crucial 3200 ram (stable not oc'd yet)
2tb M.2 ssd
Corsair HX1000 (with custom cables from cablemod) - 2 seperate cables from PSU not a split cable
Thermaltake p5 "case"
Win 10 pro
g-sync monitor (inc this detail incase)
Custom loop (temps full load on gpu approx 61c max, CPU approx 70c max - set for silence, low temps when fans set higher...)
I set the power limit to 120% on MSI afterburner and tried to overclock the gpu - for hours...and hours. Every single 3dmark run would fail, overclocked or not.
In my frustration I decreased the power limit to 100%, put in +0mhz gpu oc and memory to +850 and it ran fine. I then tried +50mhz gpu oc and set the power limit to 105%, and it ran fine with a decent score (approx 15000+https://www.3dmark.com/spy/10182225) - Gave up on a semi high, so i stopped here on testing.
The problem I am having is when I increase the power limit in any overclocking tool (MSI/Gigabyte) the GPU flashes to a black screen on 3dmark and skips to the next test, then will fail that too.
Heaven bench runs fine at 120% but doesnt draw over 300w according to gpu-z.
Would this be a PSU fault? Single and Multi rail tested
Forgot - when power limit set to 120% it emits a little scream (lol) would this be the coil whine? It does get very noticable, but im fine with it.
First build in many years of saving, frustrated old man needs help! Thank you in advance.
And sorry if this is in the wrong thread.
Specs -
2tb M.2 ssd
Win 10 pro
