Rubber gromits
2 Nov 2007
Ok guys i brought 5 of these for my silverstone TJ-09 case last november, my case needs a good clean so im stripping it down the weekend. When i built it i couldnt workout for the life of me how these fitted correctly. anyone give me a heads up, i guess they help reduce vibrations ???
orangy looking things in that image
pull them through the holes for the screws and into your case. simple enough, seeing as you're stripping the case down it should make fitting a lot easier for you.
This is the way i thought with the thicker end mounting against the hard side of the case. But then i cant get them to clip into the mounting area inside my case..:confused:
you'll be fine just using the screws, provided you get some rubber washers between the case and fan.
