I've got some fan in my case that is vibrating and I'm going to put a stop to it. I'm going to rebuild the entire pc again, after a clean, and I'd like to use rubber washers on all the screws I use (to cancel out the vibrating sound) I mean every single screw in the entire PC that I can fit a washer on I'll do it so I need different sizes. I've tried rubber o rings before but they didn't work that well.
Can anyone recommend where to get them and what I should be looking for size wise.
