Ruby text
24 Nov 2002
38.744281°N 104.846806°W
Using Regexp one can locate a string within a text file I want... however, how do I copy the data from the following line?
E.g.
#Monkey's Name:
Gregory
I would want to extract Gregory, not "#Monkey's Name:"....
I know it's simple but I can't thinK!
I'm a ruby beginner, so there's probably better ways, but I think this works ok :
Code:
file = File.new("input.txt", "r")
while (line = file.gets)
        if line.match(/^#Monkey's Name:/)
        then
                result = file.gets
                break
        end
end
result = Gregory
Cool!
How would I amend the above so that it would cope for any "# Variable :".
I.e. it would read the entire file and store the line under each "# Variable :" in tab delimindated format.
So,
# Variable1:
blah1
# Variable2:
blah2
# Variable3:
blah3
Would merely become "blah1 blah2 blah3".
Code:
result = "";
        if line.match(/^# Variable/)
        then
                if (result == "")
                        result = file.gets.chomp;
                else
                        result += "\t" + file.gets.chomp;
                end
        end
end
puts result
Okay... new problem.
It appears that it isn't JUST the single line after the # Variable..
It could be:
# Variable1:
blah
#Variable2:
blah
bob
dee
#Variable3:
etc..
So I suppose the logical thing is to only extract the text 'between' the #'s?
Just keep reading lines and appending, until you read a blank line. Then abort the inner loop and read lines in the outer loop until you find a "# Variable" line.
