Just bought a logitech wirless rumblepad 2 to play TDU and TOCA - basically to solve the problem of using keys and the the weeving from side to side you get with digital controls.
The problem is with the pad in TDU the wheel starts to move a couple of mms either side of the middle point which makes it really difficult to judge the steering as when you move it to the side you get nothing then suddenly you're well off to the side.
Is there any way to fix this so it starts to mvoe right from the middle point. Ive tried the sensitivity controls in TDU and I have latest logitech drivers installed.
