Hey guys. The idea seems basic, but I haven't seen it done. Say I have a normal desktop computer, and a mini itx system. I want to run both at once.
The pci psu takes 12V dc from a transformer and splits it up as required by the motherboard and peripherals.
Graphics cards run off 12V DC.
Can I therefore directly wire the 12V pins on a pci-e power cable together, and the 0V pins together, and use these two cables to run a pico psu block?
Obviously the mini-itx system wouldn't work with the main one turned off. I'm relying on the idea that whenever the atx psu is on it offers a steady 12V across its pci-e contacts, and continues to do so regardless of load until the computer is powered down. I don't suppose anyone knows if this is maintained during reboots?
It's also an issue that forgetting to turn the mini itx system off would lead to it suffering many hard resets. Can anyone offer more detail on the specifics of this?
