- 4 May 2009
- Edinburgh, UK
I've been running my custom loop system for a couple of years now. I'm planning to clean my loop, replace the discoloured soft tubing, and change the fluid. I've got the new fluid, and the Blitz Basic kit.
My plan is to drain the current fluid, run the Blitz Basic through it, then (if necessary) hand-clean the blocks before flushing with deionised water and loading in the new fluid. During this process, I'm also
The instructions say to circulate the fluid for 24hrs. Does the system need to be cold for this, or can it be running?
Do you have any other advice for a cleaning noob?
