Runaway USB Mouse in XP
15 Jan 2006
Scotland
Hi,
My USB (wired) mouse regularily shoots to the edge of the screen of it's own accord. I have tried several different mice and get the same problem. All of the mice work fine when used with my laptop.
I have tried fiddling with some of the settings in the start/control panel/mouse but it make no difference.
Any tips or advice would be appreciated.
Axel
I get the same on my PC at work. Only with USB and tried different mice and it makes no difference. Cursor shoots upto the top left for 5-10 seconds, maybe every 3 hours or so.
Gives me an excuse not to do any work for a few seconds at least. :D
Never had it home though (running XP MCE and Vista)
marc2003 said:
dodgy usb port? can you test using an alternate one? :)
Thanks for that. I have swapped the mouse to another port so I will see what happens.
Axel
Axel
Yes, still the same.
I have now swapped the USB extension cable (1.5M long) and will try that.
Axel
Axel
Short test, about 30 minutes intensive use of mouse playing backgammon, but not a flicker so the problem appears to be resolved. Dodgy USB extension cable!
Thanks to marc for the clue!
Axel
It's probably the surface of the desk/matt/whatever that's confusing the mouse, or perhaps a hair near the sensor. Try it on a sheet of plain paper or something.
I had this problem with a old optical mouse several years back, It was windows causing it and we reinstalled it and it stopped. Very strange.
