Runni gtemp for Amd 4000+
Received me AMD Athlon 64 4000+ San Diego (Socket 939) - OEM (CP-175-AM) last week.
Having looked at temp monitoring for it - i find it idles at 40 degrees and goes to around 55 degrees when under load - isnt this a little high? i need some new thermal paste anyway which ill buy tommorow - do i need to try and get the old stuff off before i put the new paste on? Im running stock heatsink and fan atm
thanks
Any help much appreciated
thanks
(check your sig)
