Running 3 monitors - problem with using NVIDIA PCIE & ATI PCI?
1 Oct 2003
Huddersfield
Hi guys, I've just bought a third monitor and am now shopping for a cheap PCI card to power one of the 3 screens.
My current card is an 8800GT, I can't afford (nor want) to get another for SLI for thought I'd be best getting another PCI card to run.
Does anyone see any problems in runing a PCI ATi card alongside my 8800GT?
Thanks
Oh no definately not using Vista :) On XP.
I'm not interested in 3D performance across all 3 screens, I will only be using one of the screens.
james would a 7300GS affect the performance of the 8800 in any way? Thanks
Should be as they use Gforce 8 drivers but what do you awnt to run on it? That thing wont do games.
I use ultramon and will disable 2 of the monitors when I want to game, the monitor I will leave running will be powered by the 8800GT, again, you don't think running a lesser card at the same time will affect the performance of the 8800 in any way do you?
Great :) Thanks chaps! Now all I need to do is check if the 3 monitors will fit on my desk, and buy some speaker stands :D
Edit: Got a 7200GS.
Aye just got one from the auction site, james.miller seems to be ok with similar hardware, if it doesn't work then I'll shake my fist at him.
There's a 7 day return limit anyway :)
