Can someone try and please help me understand the black magic that is electric?
I have a solar panel at home with the following specs:
https://imgur.com/a/DXRDtb3 (how do you insert images now!?)
I am looking for the cheapest and easiest way to hook it up to a 12v radiator fan. The one I was looking at was 80w I think.
It only needs to come on when the suns out so wasnt going to bother with a battery, but will the 19v damage a 12v fan?
Do I need to put something in the line to regulate voltage or will it be ok? I heard solar doesnt always put out max voltage anyway?
If its cheaper or a lot easier to just get a new panel Id do that.
Thanks
Thanks
