Running a 360 via PC?
A5H
A5H
Permabanned
7 Aug 2005
Teesside
Possible?
I'm in uni at the mo and don't have a TV.
I have 2 19" TFT monitors hooked up to my PC. I understand that I could hook the 360 to a monitor quite easily. But the thing is, I would like to let the PC use it still.
Is this possible?
Also, I would like yo use the PC speakers whilst keeping them on the PC... Possible? (X-fi Xtreme music soundcard if that matters).
Thanks for any help. It's appreciated.
Regards,
Ash
Excellent. Thanks mate.
Only one input unfortunately. So I'll try get one of those switches.
I'd like to play online too, but have only one internet connection. Is it possible to get a switch for this? Or would I have to unplug the PC to plug this in?
Thanks again.
Ash
Edit: Can you stream mp3s from your PC to your 360? Is it possible to load them onto the HDD?
If yes, is it USB>USB or what?
You can stream mp3's from your pc, yes. Do this by getting a wireless adapter, assuming you have a router, which I doubt as you're wondering about sharing net connection.
If you want them on the xbox HDD you'll either need to shove the cd in, or get one of them USB adapter thingies.
So, to sum it up. Grab a VGA lead. Grab either one of them USB things that lets you put stuff from PC onto the xbox hdd or grab your cd's
