22 Feb 2009 at 13:09 #1 gobbo gobbo Soldato Joined 25 Dec 2002 Posts 2,862 Basically I want to run some commands automatically when ever I launch a terminal or logon via SSH. Is there any way of doing this?
22 Feb 2009 at 13:31 #2 JIM_BOB7813 JIM_BOB7813 Soldato Joined 4 May 2004 Posts 3,270 Assuming you are using Bash, google for .bashrc, should be able to run a script/command from there AFAIK.
22 Feb 2009 at 14:06 #3 BigglesPiP BigglesPiP Soldato Joined 8 Mar 2006 Posts 13,311 Location Telemark stick the command in a file called "~/.[name_of_your_command_line]rc".
22 Feb 2009 at 14:09 #4 gobbo gobbo Soldato OP Joined 25 Dec 2002 Posts 2,862 Thanks, found the file I need now, in Mac OS it's just bashrc rather than .bashrc which is where the confusion was coming from!
